Exhaust tip question
Old 03-18-2012, 11:46 PM
Medic/Z28's Avatar
Default Exhaust tip question
I saw a camaro on google images that had dual exhaust tips on each side of the new camaro. How would you guys go about cutting the plastic to accommadate(spelling?) the tips and look like it came that way from the factory?
Old 03-24-2012, 12:44 AM
No Hope's Avatar
Go down to Sears and get a hole saw that is the diameter of the original hole. It's easy to do, you just lock the hole saw in a drill. Layout where you want the center of the hole, then put a dimple in the spot with a small diameter drill bit 3/32 should do it. Then drill away.
Make sure you get the arbor with the hole saw or its no good.
Good luck
Old 01-26-2013, 07:46 AM
98sickspeedblkta's Avatar
Hello and good luck
Quick Reply: Exhaust tip question
