What PSI does the 2010-2015 V6 low pressure Fuel pump run at?
Old 04-27-2015, 09:45 AM
ryeguy2006a's Avatar
Default What PSI does the 2010-2015 V6 low pressure Fuel pump run at?
Hey guys,
I am looking at swapping an LQ4 into my 1968 Camaro and a company called Rick's Tanks makes a stamped steel tank that will accept the 5th gen Camaro fuel pump assembly for a bolt in swap tank. I really like the idea of having a stock in tank pump. My question is what fuel pressure do the V6 fuel pump assemblies run at? Brand new the v6 assemblies are around ~$120 whereas the V8 is ~$350.
The engine is stock so I wouldn't need a really high flowing fuel pump, but wondering if the stock fuel pump is capable of providing 58 psi with the Vette Fuel filter/reg? I searched around and couldn't find any information on it.
Thank,
Ryan
Old 05-25-2015, 09:48 PM
1KillerSS's Avatar
According to HPTuners, the tune file for a 2013 V6 will run at 58psi and I think, "think", as high as 70psi. But don't take my word for it. Obviously this is not the Direct injection V6.
Old 05-26-2015, 05:40 AM
eseibel67's Avatar
Spec on the V6 pump is 40-65 PSI KOEO, 40-47 PSI running.
Quick Reply: What PSI does the 2010-2015 V6 low pressure Fuel pump run at?
