anybody using electric vacuum pump for brakes on hot cam
Wanted to see if anyone running a electric vacuum pump for brake booster where cam has robbed vacuum.
Also what brand did you use & how quiet is it, how did you plumb it?
What pressure did you set for it to kick in?
I'm only getting approx 6 inches at idle, roun 8 when cruising, brakes feel ok but I think in an emergency they may run out, so just wanted to see if a favorite type or brand is being used out there.
Not looking for a tank at this stage as room is very limited now.
