ATI ProCharger Systems are now available! - LS1TECH
Gen 5 Camaro Power-Adder Tech Supercharger, Turbo, Nitrous
Thread Tools Search this Thread
Old 07-03-2009, 09:08 PM   #1
EPP
Thumbs up ATI ProCharger Systems are now available!
http://www.exoticperformanceplus.com...html?item=1893
ATI ProCharger HO Intercooled System with P-1SC-1
http://www.exoticperformanceplus.com...html?item=1914
ATI ProCharger HO Intercooled Tuner Kit with larger head unit options.
Check them out, 12 rib is also available! Bob
EPP is offline   Reply With Quote
Old 07-03-2009, 10:58 PM   #2
MelScrilla's Avatar
sweet I cant wait to see dyno numbers
MelScrilla is offline   Reply With Quote
Old 07-04-2009, 07:50 AM   #3
8 sec potential, 12 sec slip
ChevyChad's Avatar
Badass!!!! They finally did it right with the 5th gens and put them up top- front and center where they can be appreciated! Well done procharger! I cant wait to see a 5th gen F1A
ChevyChad is offline   Reply With Quote
Old 07-04-2009, 08:06 AM   #4
No where else to run the filter huh?
whytryz28 is offline   Reply With Quote
Old 07-04-2009, 08:21 AM   #5
Administrator
unit213's Avatar
Quote:
Not really. That's the same place the S197 Mustang GT kits have the filter too. You'd think it would suck in nothing but hot air and kill power badly, but it really doesn't.
unit213 is online now   Reply With Quote
Old 07-04-2009, 10:13 AM   #6
LSXFORMULA99's Avatar
i love it. i wish they made a bracket for the 4th gens to mout theres up top so you can see it..
LSXFORMULA99 is offline   Reply With Quote
Old 07-04-2009, 11:09 AM   #7
ChevyChad's Avatar
I guess if nothing else, the engine cover may have some actual use in this case by keeping some of the heat retained and away from the filter
Old 07-04-2009, 01:19 PM   #8
EPP
The ingested air does get compressed and further heated by the blower, then cooled down by the 3 core intercooler before being routed into the throttle body. If it wasn't for an efficient intercooler, this system wouldn't work as well as it does. Bob
Old 07-05-2009, 09:09 AM   #9
Ws6Wicked's Avatar
looks great!!!
Ws6Wicked is offline   Reply With Quote
Old 07-05-2009, 05:14 PM   #10
EPP
We might end up coming out with a hood that would enable a larger air filter assembly to be incorporated into it, if there is enough interest in one. Bob
Old 07-05-2009, 11:56 PM   #11
scottywheels's Avatar
Bob I talked to Procharger two weeks ago and they said they are also offering the D1sc in the P1sc place obviously not with tuning. Also where is the cooler, front mount of underneath like the older kits?
scottywheels is offline   Reply With Quote
Old 07-06-2009, 04:28 AM   #12
EPP
Thumbs up
Check them out! Bob
Yes indeed. You can go all the way up to the F-1C/F-1R.
The 2010 Camaro comes with a large single front mount 3 core intercooler. Bob
Old 07-06-2009, 05:09 PM   #13
Wnts2Go10O's Avatar
christ, that was quick..
Wnts2Go10O is offline   Reply With Quote
Old 07-06-2009, 05:24 PM   #14
NumberOneSled's Avatar
Any advantage in upgrading to the D-1SC on a stock shortblock and pump gas motor?
NumberOneSled is offline   Reply With Quote
Old 07-06-2009, 07:24 PM   #15
I have run the P1sc D1sc and the F1c and if you are putting it on a stock motor the D1sc will be fine. THe $300 upgrade price is much better then the $1000 it cost later on to upgrade.
Old 07-07-2009, 05:17 AM   #16
EPP
Thumbs up
I agree, and I recommend going with the D-1SC. The only problem is the P-1SC-1 is the only unit that can be ordered with the injectors and tune from ProCharger. The D-1SC can be ordered in the tuner kit, which does not come with the injectors and tune, so you would need to buy injectors and get the car tuned by a shop that knows what they are doing. For many enthusiast though, this isn't a problem.
All of these units come with a one year warranty, the P-1SC-1 is offered with an additional two year warranty by sending in the warranty card and $49.00 when you receive the system. Bob
Old 07-07-2009, 11:07 AM   #17
Hemi Sponsor
Nasty N8's Avatar
We also offer our Dual intank pump assemblies and stage 3 street kits for the 2010 Camaro sold through Exotic with your kit.
Nasty N8 is offline   Reply With Quote
Old 07-07-2009, 07:12 PM   #18
ChevyChad's Avatar
Oh its way more than $1000. More like $1500 later on. Get the D1 now so you won't regret it later.
Old 07-07-2009, 07:20 PM   #19
It would be nice if the new system is able to deliver a flatter dyno with hp and tq numbers being closer together than centris in the past.
Other tuners have been able to design custom centri systems to deliver boost curves close to TT's and PD blowers. I hope Procharger can do the same.
Because of it's heavy curb weight, the Camaro is going to need as much boost, as soon as possible, down low in the RPM's.
427C5 is offline   Reply With Quote
Old 07-08-2009, 04:50 AM   #20
EPP
Question
How about a torque curve like the one above? The above dyno graph is from a 2005 Cadillac CTS-V. We started with a new LS2 block, and added a Callies crankshaft, Compstar rods, Diamond pistons, our EPP blower cam, and off the shelf AFR 225 heads. We then topped it off with a FAST 92mm intake manifold. To this engine we added our modified ProCharger GTO kit, using the ProCharger F-1A blower. Here is a link to this CTS-V. http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Related Topics
Thread Thread Starter Forum Replies Last Post
ATI ProCharger F-3R-131 - New $4000.00! Exotic Performance Plus Forced Induction 12 12-23-2009 12:15 PM
Great ProCharger Prices at EPP! Exotic Performance Plus Sponsor Sales & Specials 25 12-14-2009 04:18 AM
ATI ProCharger GTO Overdrive Pulley for Fluidampr Available at EPP Exotic Performance Plus Forced Induction 1 09-25-2009 05:38 AM
Our new GTO drag car - Warhawk with ATI ProCharger F3R Exotic Performance Plus Sponsor Vehicle Projects & Shop Tours 0 03-01-2008 08:25 AM
Our new ProCharger showed up! Exotic Performance Plus Forced Induction 50 01-01-2008 04:42 PM
Tags
2007, 2010, ati, camaro, cost, f1, f1a, f1c, gt, gto, kill, mustang, owasso, p1sc1, procharger, trans, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
