Gen 5 Camaro Power-Adder Tech Supercharger, Turbo, Nitrous
need stock tvs2300 parts
Old 01-16-2011, 10:14 PM
jay_lt4's Avatar
Default need stock tvs2300 parts
to anyone who has changed the rear pulley set up,, im looking for the factory plate/ tensioner for the rear pulleys,,, the tvs2300 i have has been modified at one point and has a different plate on the rear(looks like the 14rib over/ underdrive set up) but it has stock 10rib 3.25 / 3.00 pulleys, but no way to tighten the belt ,, ill post pics
so what i have is the 14 rib plate and tensioner, and this will not work with the 10 rib pulleys and belt,,
it would work if i could find a longer belt with the 14 rib tensioner pulley but i have been checking and no one makes a longer 10 rib belt.
the 10 rib belt does fit tight now but i have no way to re-tension it after everything wears in.
i also need the front idler pulley,
Old 01-20-2011, 12:37 PM
jay_lt4's Avatar
found out the 3.25 / 3.00 pulleys are why the stock 10 rib belt wont fit with the tensioner,,, 3.00 pulleys on the way,, then i should be set
Quick Reply: need stock tvs2300 parts
