Gen 5 Camaro Power-Adder Tech Supercharger, Turbo, Nitrous
Granatelli TWIN TURBO KIT
Old 10-08-2013, 01:19 PM
  #41
granatelli sales's Avatar
we're very proud of the car; it's not only fast and pretty....
but it also wins! congrats to our customer (guy martin)!
Old 05-09-2014, 02:58 PM
  #42
25% off all turbo kits this month
Old 05-31-2014, 11:34 PM
  #43
Toxic-Evo's Avatar
Originally Posted by granatelli sales
A detailed break-down of the 2010-2011 Camaro Twin-Turbo kit and its components are as follows:
2 x PTE6265 Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min
Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
2 x PTE 46mm Waste Gates Insure Maximum Control Over the Monster Turbos. Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
All stainless steel and Heat temperature coated exhaust system components ensure a lifetime of reliability
1 x 50mm Tial Blow Off Valve
3 x Largest Front Mount Intercooler are Hi flow Bell cores with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
All the necessary Vacuum ports required to assist in installing the boost controller
1 x Oil Scavenge Pump & Brkt
Thermal Heat shielding for all effected lines
GMS Oil Feed & Return Line Kit are all precision clamped and crimped to ensure leak free connections
GMS/TTi 3.5” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
GMS/TTi 4” 6061 Aluminum Charge-pipe
GMs/TTi 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection
GMS/TTi Aluminum Lower frame cover to ensure debris free road travel
The only TT kit that does not hang below the frame rail, ensure plenty of ground clearance
AEM Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
We offer many options from short blocks and long blocks to various turbo size upgrades and color choices. Factory Silver Powder Coated Tubing – Special Colors Available on Request.
Test - Granatelli Motor Sports / TTi Gen 5 Camaro Twin Turbo Kit - YouTube
Video was from 2010 our kit makes well over the power that power now
Granatelli Motor Sports - LS Compound Boost Motor - YouTube
1200hp Camaro engine
can you please expalin. in you posting you have 4" compressor inlets and 4" alum with KN filters. Up above i have it in red.
but the turbo pictures all show PTE's E cover which is a 3" inlet. and if you watch the last video in my quote. @ 4:23 you can see the 4" TB tube next to the filter tube and they are not the same...
im looking ot get a kit but i really have to know if i can get 4" inlets on it...
thanks
Old 06-05-2014, 12:02 PM
  #44
To avoid confusion. We make reference to the inlet piping as opposed to the discharge piping which is the "inlet" to the motor. The tubing (on the pressure side, meaning the discharge of the turbos is 3" from the turbos to the intercooler. Each turbo has its own feed into the intercooler insuring no pressure drop and no "post-compressor surge" all tubing exiting the intercooler going to the throttle body is 4"
As for the air filter intakes. Each turbo has its own inlet tubing as well. The tubing is 4" at the front and chokes down as it mates to the inlet of the PTE turbos. Again time went into designing a free flowing intake rather than simply putting a filter directly to each turbo and letting them hang under the car.
Old 08-05-2014, 12:12 PM
  #45
2010 SS Camaro Granatelli Twin Turbo System at 10 psi and newly installed 4L80E trans.
Yank 3600 Turbo stall, Open Waste gates.
(Stock Motor and cam, stock fuel pump,stock exhaust piping lol).
Made 575whp on 7.5 psi with the M6 transmission,
Also Note - No Turbo Lag
Old 09-22-2014, 04:49 PM
  #46
25% off all turbo kits till October 31
Old 09-22-2014, 04:55 PM
  #47
Granatelli's Avatar
This is Joe Granatelli. Hello everyone. I see my guys offer discounts but I wanted to get a but more technical. Does anyone have any questions and results they want to talk about?
Old 09-26-2014, 04:16 PM
  #48
sik02's Avatar
I need this for my 2012 2ss L99.... Price
Old 09-26-2014, 05:00 PM
  #49
Granatelli's Avatar
PM Sent
Old 10-15-2014, 04:07 PM
  #50
Old 12-16-2014, 03:32 AM
  #51
Order today get before Christmas
Old 12-30-2014, 06:22 PM
  #52
RING IN THE NEW YEAR WITH 30% SAVINGS
To help ring in 2015, Granatelli Motor Sports is offering 30% off all GranatelliMotorSports.com orders from January 1st, 2015 - January 4th, 2015. No discount codes necessary! Just add the items to your cart and watch the savings pile up!
Click below to start shopping on our website:
Old 12-30-2014, 10:37 PM
  #53
IronBlocked's Avatar
I love 5gens, great work guys
Old 02-16-2015, 12:25 PM
  #54
Old 05-19-2015, 01:26 PM
  #55
Old 08-11-2015, 11:21 AM
  #56
Old 08-12-2015, 04:34 PM
  #57
smileyou's Avatar
Pm Prices
Old 04-25-2016, 05:43 PM
  #58
Just built another 650 rwhp camaro with a Granatelli turbo kit
Old 05-27-2016, 01:20 PM
  #59
Old 08-08-2016, 02:08 PM
  #60
Boooost
Quick Reply: Granatelli TWIN TURBO KIT
