UMI New Product Release- 2010 Camaro Drive Shaft Tunnel Brace
Old 07-21-2010, 03:01 PM
UMI Performance's Avatar
Default UMI New Product Release- 2010 Camaro Drive Shaft Tunnel Brace
2010 Camaro/2008-2009 G8 Tunnel Brace
Application:
2010 Chevrolet Camaro
2008-2009 Pontiac G8
(All Models)
Find more information HERE
Installation write up HERE
The UMI heavy duty tunnel brace reinforces the tunnel area and reduces chassis flex by replacing the weak factory stamped steel brace. Reinforcement of this area is critical because of the drive shaft carrier bearing location. The UMI tunnel brace is fabricated from CNC machined 3/16” thick mounting plates, rectangular tubing and MIG welded. The tunnel brace is a 100% bolt in application and uses existing factory mounting holes. Installation requires basic hand tools and can be completed in less than a half hour.
$89.99
If you have any questions please ask.
Thank you
Ryan
