wheel stud help
wheel stud help
I need some help. does anyone know where to locate some longer wheels studs for this camaro SS ?? I have tried jegs and all the local shops and no-one has one to match. I added some aftermarket wheels and with the needed 1/4 inch spacer(to clear brakes) I only have 4.25 turns before the lugnut is tight. Any thoughts or ways to cheat THANKS
LS1Tech Premium Sponsor
I searched and searched for the receipt but came up empty-handed or i would have a part number for you guys. We matched up a stud at Advance Auto parts that worked perfectly. I remember that it fits a 3/4 ton Chevrolet truck but I am unsure of the year. It was a common Dorman part number that they had in stock so just knock one out and run down to your local Napa. They should be able to just look up late model 14mm GM truck studs.
Whoever finds it, make sure you post the part number!
LS1Tech Sponsor
M14x1.5x28 threaded. 58 is total length. That is what GM says. Ill get some measurements tomorrow on the knurling for the peeps that still need them. I have some here on hand.
Also FYI, its the same wheel stud used on the Equinox, Lacrosse, '11 Regal, Astro van (03/05), S10 trucks 98-05, full size vans, Full size trucks 99+. Just to name a few.
