Old 05-18-2016, 01:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Rear 15in wheel conversion experiences
Old 07-23-2015, 02:09 PM
NOTAV6's Avatar
Default Rear 15in wheel conversion experiences
Been looking at BMR and a few other companies that have the conversion.
Looking to see what experience people have had with these conversions. Fitment, wheel options after the conversion and so on.
Thank you
Old 07-27-2015, 07:06 PM
MUSTANGEATER's Avatar
The BMR setup was extremely easy, it's a few bucks, but works well, and comes with everything you need. I went with some Bogart 15X10.5 Wheels. I ended up mini tubbing and running a 325 Drag Radial.
You can basically run any 15X10, 5X120MM wheel with the right backspace though.
Old 09-15-2015, 03:59 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
I have a complete setup that uses Strange Brakes on the stock IRS
Old 09-23-2015, 11:05 PM
14ZL1M6's Avatar
Do you have this on your site? I couldn't find it. If not, could you post some pics of your setup please?
Old 10-01-2015, 10:45 AM
ssvert99's Avatar
I actually developed this stuff back in late 2011, been so busy with the 4th gen stuff never really got into production till recently. This is the ONLY rear IRS with the lightweight Strange brakes.
Old 10-01-2015, 12:17 PM
SLOW SEDAN's Avatar
The BMR drag suspension and V6 brakes clear Racestar 15x10.
I debated the BMR brake kit but $2,000 vs $300 I figured I could live with the weight difference.
Old 10-01-2015, 01:07 PM
BMR Sales2's Avatar
Thank you
The ARH/ Fark's Supercars 2010 Camaro uses the BMR 15" wheel conversion package with a different shock and it is the fastest 2010+ IRS Camaro in world right now. It regularly goes 7.6X @ 178 in the 1/4 mile with the high 1.1X to low 1.2X 60ft times. So the setup is proven and it works.
This is also the same setup we use on our BMR 2010 Camaro that is 9.2x car and normally sees 60ft times in the low to mid 1.3X range.
If you decide to use our BMR setup let me know and I would be more than happy to see what we can do for you on it.
Thanks for the feedback! We appreciate you choosing BMR for your suspension needs. If there is anything else we can ever do for you let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-02-2015, 01:44 PM
14ZL1M6's Avatar
Very nice! What is the cost for this setup?
Old 10-05-2015, 12:02 PM
ssvert99's Avatar
I can do the whole Drag Race package for 4800.00
This is the complete front and rear packages.
Rear includes the full adjustable control arm set, toe rods, long travel double adjustable coil over shocks(uses softer spring than other kits), upper control arm rear pivot bushing, and tubular chromoly anti-roll bar. New GM spindles are machined to accept the Strange lightweight brake kit, stainless hoses, line adapters, and all hardware is included.
Front Brake kit is complete with calipers, rotors, hoses, brackets, and hardware.
Additional savings are possible with a wheel and tire package as well!
Old 10-10-2015, 03:15 PM
I appreciate you guys! Have you guys ever decided to build some front suspension components for these cars? I would love that, with some matching Wilwood brakes.
Old 02-13-2021, 09:11 AM
JD TreviƱo's Avatar
[QUOTE=ssvert99;18966354]I have a complete setup that uses Strange Brakes on the stock IRS
Attachment 647561
what kind of wheels and tire size u running, looks sick!! 🔥
Quick Reply: Rear 15in wheel conversion experiences
