Dyno Tune With Possible Drivability Issue - LS1TECH
Gen 5 Camaro Tuning, Diagnostics, Dyno results Tuning problems, solutions, dyno results for Gen 5 Camaro
Thread Tools Search this Thread
Old 11-03-2016, 03:24 PM   #1
Default Dyno Tune With Possible Drivability Issue
I have a 99 Camaro with a LQ9 with a Comp Cam Part# 54-458-11 and the supporting mods.
Every since the install been trying chase down a flat spot in the power band, some days the car runs better then others. Its more noticeable if slowly tipping in the throttle. Car gets loud and bogs with loss of power like im pulling a trailer.. from dead stop to about 3500 rpm ,then it takes off
After the install the mechanic told me he had tune so close he didn't feel I needed a Dyno tune. I took it t a Dyno shop anyways , he said on the dyno everything checked ok on the car and he says he squeezed more HP out of it.. 418 HP. I really feel this shop did nothing but mess up my down shifting, down shifted into 2nd before going here
After I got the car back it ran good that day ,then the next day the flat spot came back.and also noticed it had no kick down into 2nd gear when floored from 40 mph.. just goes into 3rd.. Dont trust going back to this dyno
I took it to a performance shop , owner has a modded WS6 he drove car , said it had plenty of power and cant duplicate problem. All looked good on scanner
Picked the car up, was running strong, next day the flat spot came back.
So my question is this,.. Im taking it to another dyno shop and the tuner is one of the best here in AZ with LS engines.. If I have a bad sensor and it shows on the dyno, will he still be able to tune it? I really feel it has to do with the tune...
Have replaced :
O2 sensors
MAF
Throttle Pos sensor
ne
Zaskar is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Boring Everyday 500 HP LS1 Darth_V8r Dynamometer Results & Comparisons 43 01-06-2017 08:01 AM
5.3 Thirdgen, New cam, Heads, and Dyno Tune.. I think i lost power Mgg4591 PCM Diagnostics & Tuning 5 05-18-2015 09:30 AM
Evo Shop Dyno Day Competition Incident Dissident Western Members 66 12-16-2011 01:49 AM
How much will dyno tune help my full bolt on 01 WS6? getcha 01 PCM Diagnostics & Tuning 3 09-26-2010 09:15 PM
I think I just washed the rings on my motor. PewterZ28 Generation III Internal Engine 32 04-02-2007 02:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
