Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
What are stock injectors good until?
Old 07-27-2012, 12:58 PM
Gun5's Avatar
Default What are stock injectors good until?
I have
644/614 230/238 111 Comp Cam
Ported TB/Intake Mani
Cold Air Intake
JBA Big Boy Headers (Stainless)
3" out the back
Underdrive Pulley
Should be over 500+ rwhp
Old 07-27-2012, 04:28 PM
blake b's Avatar
Your stock injectors will work. I believe the same injectors are used in the LS7 and it has 505hp from the factory and they aren't maxed out. If this is in your 2010 Camaro SS, you could also upgrade to a ZL1 fuel pump.
If you are tuned, what was the duty cycle? If you aren't tuned, check the duty cycle during the tuning process.
Old 07-27-2012, 04:53 PM
DietCoke's Avatar
500+ on what planet? You might see 460-470 out of that combo.
Old 07-27-2012, 04:55 PM
Gun5's Avatar
have seen it, and cam only they are making that plus im getting tb/mani and underdrive.. this isnt a little cam
Old 07-27-2012, 06:35 PM
DietCoke's Avatar
Not on any legitimate dyno they aren't. Sorry to bust your bubble. This isn't a corvette, that cam isn't large, and although texas has nitrous air, it isn't going to happen.
Old 07-28-2012, 12:50 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
Good-sized cam but 500rwhp I'd say only if the dyno operator sprays your car with a 50 shot at the same time.
Old 07-28-2012, 03:57 PM
Rhino79's Avatar
I agree, thats a 470 to 480 setup on an m6, 450ish on an auto.
Old 07-28-2012, 03:59 PM
Rhino79's Avatar
BTW, I run a 230/244 on a 111lsa. I put down 463 on 92 octane. 474 on e85.
Old 07-30-2012, 02:14 PM
Gun5's Avatar
whats your lift rhino? and cam with bolt ons (no underdrive or ported mani/tb *ls2portworks) hit 470-480 have called 2 places (texas speed, LMR) have seen many dyno's.. i guess underdrives and the porting does nothing... underdrive lets say is 5 and mani tb is 10 (which i think is low balling both..) iv built 5-6 500-1100 hp cars and have always hit my mark and the cars have ran out real hard
not saying yall are lying, but if it doesnt work guess ill port the heads then spray it for ***** and giggles since money isnt a issue
Old 07-30-2012, 08:26 PM
Rhino79's Avatar
Well it depends on the dyno...lol. .588/.607 lift on my cam. Ported tb and mani may be worth 7-10 and I dunno on underdrives. Is this an auto or stick car?
Old 07-30-2012, 09:42 PM
FIREHAWK #07's Avatar
i agree; 460-465 would be my guess. Vettes see better numbers than Camaros- even if they have the exact same mods/cam. Theres also a discrepancy in numbers from one dyno to the next; some dynos tend to give happy numbers.
Old 08-01-2012, 05:45 PM
Higgs Boson's Avatar
I agree, this will not hit 500 on stock cubes and that cam. **** I had a 408 in a vette with a 236/244 @ .625 that made 49x....on a realistic dyno. That was with heads, cam, LTs, FAST intake/tb, etc etc....
Old 08-03-2012, 08:42 AM
Gunslinger09's Avatar
So what are the 5 Gen Camaro injectors rated at 28lbs/hr?
Old 08-03-2012, 02:20 PM
Rhino79's Avatar
No they are 42 lbers I believe.
Old 08-04-2012, 03:19 PM
NOS LS1's Avatar
LS3 Injectors are 41 lbs / Hr.
Old 08-05-2012, 09:39 PM
Gun5's Avatar
ok i understand yall have built some cars
my LS1 H/C Intake (5.3 heads) with a 228/230 598 lift cam made 455/412 on 3 different dyno's from Dallas to Houston explain that? Ls3 has better heads, 90mm intake and a bigger cam and im using better headers... is it drivetrain loss? please explain
Old 08-05-2012, 09:40 PM
Gun5's Avatar
my buddy hit 495 with a 383 2 dyno's just stating some hard facts i have
Old 08-06-2012, 06:56 PM
Aries's Avatar
Yes. It's drivetrain loss.
You should see ~530 at the flywheel with that setup, but by the time it gets to the wheels you're only looking at 485-490ish with a VERY aggressive tune.
Old 08-07-2012, 05:35 AM
Ditto to what Aries said. The IRS seems to have more loss than a live axle for what ever reason.
Old 08-22-2012, 09:49 PM
so what did this put down?
Quick Reply: What are stock injectors good until?
