LS3 Conversion, Cam Heads+Misc
#42
I am planning to have it all done in April. While I am waiting for my heads to come back I am repainting the the engine compartment and re-wrapping the wiring harness.
#43
#46
#47
#52
Here are a few pictures of my heads over at West Coast Cylinder Heads getting their Stage 2 CNC Porting with stainless valves and BTR .660 springs.
#55
this looks good. ive been haggling my mother to do some improvement to her l99.
im also putting a ls3 in my fbody but do not know what front and rear cover to run.
what prepdid you do to the engine bay?
#56
If you are installing a LS3 into an F-Body there should be no reason to change the rear cover. Front covers are different between L99 and LS3.
#57
Other than turning off the AFM in the computer, I'm assuming that you removed the AFM lifters. Did you do anything else in regards to the oiling system? Also, are you doing the trunion upgrade on your rockers while you have it apart or are you going with something different?
Rob
Rob
#58
I am upgrading the the trunnions in the rocker arms. The stock arms work well and are light weight. I am keeping the stock L99 oil pump but I did change the oil pan baffle with one from Improved Racing.
