General LSX Automobile Discussion Non-technical LSX related topics.
Will a 2000 Camaro gauge cluster work in my 98 Ta
Old 01-25-2010, 09:58 AM
fire57's Avatar
Default Will a 2000 Camaro gauge cluster work in my 98 Ta
I am wanting to change out my gauge cluster, on my Ta bc it shows 240XXXX miles on the od!! bc it was took out of a wreaked car bc the one in my car shorted out!! I picked up a 2000 Camaro gauge cluster and was wondering what I needed to do to make it work!! I know the pins are diff on the bk.. but the plug in for the miles and od gauge is diff!!! Wondering if i took the old plug off and wired it up the same as it is on the old cluster if it would work??? they both have 9 wires and look the same all is diff is the size of the plug!! If anyone has done this lmk or if you have any info...
Old 01-25-2010, 10:28 AM
the_merv's Avatar
The 2000 won't work cause it's digital, you will need a 1998 one, that one is still Analog..
I'm not sure if you can use any others, but I know 1998 is a year that things were one of a kind.
Old 01-25-2010, 10:56 AM
fire57's Avatar
My trans am has the Digital display for the miles, is that what u are talking about??
Old 01-25-2010, 11:06 AM
406malibu's Avatar
97+ is all digital.
Old 01-25-2010, 01:51 PM
the_merv's Avatar
Not talking about the display fellas..ya the miles are digital but that is still an Analog Gauge Cluster..a 1999-up uses the Serial Data wire for like 4 different things..it will not work. You will need a 1998 one.
Old 01-25-2010, 01:52 PM
Mean Green z28's Avatar
not talking about the display fellas..ya the miles are digital but that is still an analog gauge cluster..a 1999-up uses the serial data wire for like 4 different things..it will not work. You will need a 1998 one.
+1.00
Old 01-25-2010, 02:19 PM
fire57's Avatar
Ok i see what u are talking about!!
Old 01-25-2010, 02:57 PM
the_merv's Avatar
There ya go..
Old 01-26-2010, 08:46 AM
slow's Avatar
how manys miles do you need? I have one with 50-52K and one with 87K (approx) out of 98 trans ams.
Ryan
Old 01-27-2010, 09:46 AM
fire57's Avatar
Ryan
Pm sent to you slow!!
Old 09-28-2011, 07:07 PM
jayr1SS's Avatar
@ ryan Do u have any of the clusters for a 98 camaro still available
Quick Reply: Will a 2000 Camaro gauge cluster work in my 98 Ta
