Go Back   LS1TECH > WELCOME TO LS1TECH > General LSX Automobile Discussion
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
Basic Technical Questions & Advice
Sponsored by
Stainless Headers
Click Here
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 07-19-2010, 01:05 PM   #1
Garage is empty, add now
Trader Rating: 1
Default brown foamy antifreeze
I just recently finished putting in a 4.8 in my 84 cutlass. I have put about 300 miles on the swap in the last 3 weeks and this morning I was checking over some things and noticed foamy brown antifreeze in the radiator. I checked the oil and it is still just as clear as when I put it in before starting the motor. The motor came from a local junkyard so I assume it had been sitting for awhile. I did not ever pull the heads off the motor as it was clean on the outside and the bottom end looked good (spotless inside the valve covers and oil pan as well as cross hatching on the cylinder walls). Could this brown foam be from not flushing the motor before filling the system? The motor had some coolant in it that ran out while moving it. Could old antifreeze leave rust or residue inside the motor that flushed out once it started?
b_evans06 is offline   Reply With Quote
Old 07-19-2010, 01:07 PM   #2
ss.slp.ls1's Avatar
Trader Rating: 36
Send a message via AIM to ss.slp.ls1
Quote:
If the oil looks good and you are not loosing pressure in your cooling system, I'd do a complete cooling system flush and fill it up with fresh coolant/distilled water and call it a day.
__________________
'98 Z28 M6 silver hardtop, intake, full exhaust, gears.
ss.slp.ls1 is offline   Reply With Quote
Old 07-19-2010, 01:16 PM   #3
Trader Rating: 1
The car hadn't been started in a few days and when I took off the radiator cap I could hear it letting off pressure so I assume the system ok as far as that goes and the oil looks just like it did when I poured it in the motor.
Old 07-19-2010, 08:47 PM   #4
greenturtle05's Avatar
Trader Rating: 5
Send a message via Yahoo to greenturtle05
flush the entire system and put some new coolant in and you should be good. Did you have a leak on your previous motor?
__________________
05 silverado cc~5.3~lt's w/ory~tru trac~4.11~tt3000~hd2~vette servo~dyno tuned~magnaflow~ muffler~Totaled 9-24-11
07 Sierra CC~5.3~Stock
83 chevy caprice~ ls swap in progress
greenturtle05 is offline   Reply With Quote
Old 07-19-2010, 09:05 PM   #5
Trader Rating: 1
I bought the car as a roller that didn't have a motor or radiator. The cooling system is all new except the water pump.
Old 07-19-2010, 10:29 PM   #6
V8 RWD x3 Director
1971 Chevrolet Nova
My Garage
RPM WS6's Avatar
Trader Rating: 3
What about the heater core? Original to the car? Maybe there was junk in there.
Flush the system and keep an eye on it. Hope for the best.
__________________
1998 Camaro Z28 | 2002 Camaro Z28 | 1971 Nova SS
REDLINE PERFORMANCE MACHINES
RPM WS6 is offline   Reply With Quote
Old 07-27-2010, 02:54 PM   #7
shaun's Avatar
Trader Rating: 0
this could be the case old crap in the core got broken loose and went through the system.
i would flush it out real well dont want crud going in the heads and block.
__________________
a few bolt ons and some custom touches
www.fquick.com/shaunls1
shaun is offline   Reply With Quote
Old 07-27-2010, 03:26 PM   #8
Canbarelygo's Avatar
Trader Rating: 0
what ive seen of this is that this is what happens when you mix red and green antifreeze. when you mix the kinds that arent mixable it turns into this nasty nonsense that looks like the inside of a brownie lol.
umm if that what this is then when water hits it, it should just kinda "melt" and flow away. if this stuff is your problem then take the radiator out and flush it out for about 10-15-20 mins with a water hose (depending how big of a **** you are and it should be good. then while radiator is out just run a water hose through the block for 20 or so minutes maybe more (again depending on how big of a **** you are) and you should be good to go man.
like i said try runnin water on the foamy stuff and if it kinda "melts" and flows away then thats your problem. hope this helps
__________________
99 z28 a4
neighbors think its too loud, maybe i should get mufflers....
Quote:
Originally Posted by Midnite Magic View Post
Spray that ***** out of the hole
Canbarelygo is offline   Reply With Quote
Old 07-28-2010, 12:08 AM   #9
Douchebag On The Tree
justin455's Avatar
Trader Rating: 0
Might this be what you are speaking of?
Everyone is right. Flush it well. This is dexcool that has been left in too long and has either come into contact with good old green stuff or air. Once this happens it's actually a corrosive substance that eats all the good little plastic parts (namely intakes) that GM uses. It wasn't as maintenance free as GM advertised.
Best bet is to flush it and use green. You can use dexcool again with no problems as long as you keep an eye on it, but I prefer green anyway.
__________________
Quote:
Originally Posted by V-seriesTech View Post
After you hit 200mph you go and get yourself a BJ.
justin455 is online now   Reply With Quote
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
antifreeze, brown, chocolate, colored, coolant, crud, fluid, foam, foaming, foamy, green, oil, orange, radiator, stuff
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
