LS2 swap in my 2000 trans am
Hey guys was just wondering what will be needed to put in and get running a 05 GTO motor n auto trans in my car. I have a 2000 WS6 Trans Am with 155000 miles on going to need transmission. So I was thinking of buying engine and trans from an 05 or 06 GTO with low miles and swap it in. I just need to know how hard and what I need to get it going. Ur input will be greatly appreciated. Thanks
Well if you get a whole motor all you need is harness extentions for the cam position sensor,knock sensors and a timing chain cover... TSP and Lingenfelter sells these among others...
The really big deal is the reluctor. Early LS2's have 24x reluctor wheel which is a drop in but the later ones are 58x and require pulling the crank and installing a 24x or buying a Lingenfelter conversion box...
so its a direct drop in? I have a 2000 trans am M6 and ive been planning on doing this swap. Will i be able to use the cam from my ls1? Just had a custom grind made and dont want it to go to waste. lol
There is some work involved. So don't think it will just be a "bolt in", lol..
