General LSX Automobile Discussion Non-technical LSX related topics.
241 heads on a 5.3L
Old 02-10-2011, 10:20 PM
gm50cal's Avatar
Default 241 heads on a 5.3L
I'm looking at doing a h/c/i on my 2000 t/a. When I am finished I'll have my 241 heads left over and was wondering if I can put them on a 5.3l truck engine. I've been doing some research and am getting a few mixed results. I know the increased CC will result in a lower CR = power loss. From what I've read though, if you get the heads milled down you can recover some of that lost CR. So is it worth porting and polishing my 241's and putting them on a 5/3L? Are the gains worth it to mil down the 241s?
Yes I realize that 243 and 6.0L heads are a better choice but I'm trying to get some use out of my 241s
Old 02-10-2011, 10:30 PM
LS Desert Ranger's Avatar
Im wondering the same exact thing. I have some 241 heads that I was thinkin about putting on my 5.3L because i was told they flow a lot better than stock 5.3 heads, but then you have to mill them down .40 thou to bring the compression back up. Or would it just be better to port and polish the 5.3 heads and get those milled to bring the compression up a lot more?
Old 02-10-2011, 11:30 PM
SREETRACEGUY's Avatar
just a thought if it will lower your compression then don't mill them and get a blower and put crazy boost to it
Old 02-10-2011, 11:34 PM
too much money.
Old 02-12-2011, 03:55 AM
gm50cal's Avatar
lol yeah try to same some dough here, haha
any ideas guys?
Old 02-12-2011, 08:36 AM
alamantia's Avatar
https://ls1tech.com/forums/generatio...ads-5-3-a.html
Old 02-12-2011, 11:36 AM
How much exactly do the 241 heads need to be milled down to match the 5.3L 706 heads compression?
Old 02-15-2011, 01:30 PM
gm50cal's Avatar
bump!
Old 02-20-2011, 03:37 PM
bump...
Old 02-21-2011, 11:43 AM
ocls1's Avatar
Me personally would leave the 5.3 head on there. dont see the reason on going to the 241 if your going to lose compression. Dont see the point in investing in porting and milliing them when you can do the same with the 5.3 and it would work out alot better in the long run when u decide to do a ls1 or possibly a lq9
Old 02-21-2011, 11:54 PM
Well if i went with the 241 heads i was planning on getting them milled down to bring the compression back up to equal to or greater than the 706 heads. With that being said, would you still think the 706 heads are a better choice than some milled down 241 heads? i heard the 241 heads flow a lot better than the 706's. I dont plan on getting either heads ported and polished cuz i'd rather save and invest that money into to some patriots at the very least.
Old 02-28-2011, 11:40 PM
any input on last post?
Old 03-12-2012, 05:04 PM
91sonomast's Avatar
Am I going to be stoned if I bring this thread back? So the 241 has lower CR, on a 5.3 it seems like the 241's would be great if you plan on putting some boost to it like I am. Is this a correct thought? Maybe a hand smoothing with a dremel but no other work to speak of done to the 241's.
Old 03-14-2012, 10:44 PM
91RS99z's Avatar
I put 241's on the 5.3 in my car after the ls1 died last year not thinking about them lowering the compression ratio and with a small cam it made 5 horsepower less than the ls1 on the same dyno
Old 03-14-2012, 11:05 PM
k_cash1432's Avatar
The 241's are probably going to flow a lil bit better but you should be ok if your going to be putting some boost to it may be able to get a lil bit more timing out of it with the lower CR
Old 03-19-2012, 09:05 PM
rnl35thss's Avatar
Hey 91RS99z, how small was that cam?
Old 11-18-2014, 12:51 PM
93Fox's Avatar
Any info on this? wondering what a static cr would be with a L33. Will be boosted on e85.
Old 11-18-2014, 01:23 PM
Fry_'s Avatar
L33's have either 799 or 243 heads swapping them to 241's would be a downgrade on both compression and flow.
Quick Reply: 241 heads on a 5.3L
