Troubleshooting help needed- hot start problems - LS1TECH
General LSX Automobile Discussion Non-technical LSX related topics.
Thread Tools Search this Thread
Old 05-01-2011, 09:08 AM   #1
wreckwriter's Avatar
Default Troubleshooting help needed- hot start problems
I've been having hot start problems for years on this car, nothing I do seems to help. Now, after second new starter it seems to be getting worse, certainly no better.
Car is a 08 Pontiac G8, stripped down for drag racing use. What happens is that once it gets hot it just won't start. You get a single 'click' per key turn. Only time will make it work. Once it starts it runs great.
Starter has been replaced twice, battery 3 times, starter relay once. I have a brand new top quality battery jump box, attaching it does not help. Battery voltage shows good, I keep a battery maintainer/charger on it during the week. Wiring to the starter appears ok. I keep a blower fan on the engine between rounds but it still does it.
Anyone have any ideas, no matter how off the wall? Getting desperate here, afraid to shut the car off in the staging lanes at this point.
Thanks for any tips!
Tom
wreckwriter is offline   Reply With Quote
Old 05-02-2011, 12:10 PM   #2
SOMbitch's Avatar
Classic symptoms of a bad fuel pressure regulator. That's where I would start looking first...
SOMbitch is offline   Reply With Quote
Old 05-02-2011, 01:35 PM   #3
That would cause it to crank but not start, it won't crank. Its electrical I think.
Old 05-02-2011, 03:00 PM   #4
Moderator
jimmyblue's Avatar
Voltmeter time. Start at the starter, clip right across
the case & power lead. What does this drop to when
you try and crank? At the battery? etc. You can narrow
down the point(s) of voltage drop methodically.
Don't neglect the ground side of things, ground rise
is as bad as BAT drop. Maybe when hot you have a
looser stud somewhere,
jimmyblue is offline   Reply With Quote
Old 05-02-2011, 03:16 PM   #5
Gonna try running a new ground first as its basically impossible to access the starter connections without pulling the starter. If the ground doesn't work I'll have to start as you say.
Old 05-02-2011, 06:46 PM   #6
ringmaster72's Avatar
Had this problem on a 68 Camaro I had. I ended up putting a remote solenoid on the fenderwell, that way the heat does not affect it. I am not sure if that is ur problem or not, but it worked for me.
ringmaster72 is offline   Reply With Quote
Old 05-02-2011, 06:49 PM   #7
Quote:
I heard something about this. requires a certain Ford solenoid I think?
Old 05-02-2011, 07:13 PM   #8
correct. go buy a ford starter solenoid. just use a 72 ford pickup for reference so you wont get questions from the parts store tards. google the correct wiring and your good. I did this with my nova and it worked great.
71novaguy is offline   Reply With Quote
Old 05-03-2011, 06:31 PM   #9
Quote:
Like this?:
http://www.novaresource.org/starter.htm
I work at a Ford dealer so can deal with the parts guys
Old 05-03-2011, 06:35 PM   #10
pretty sure my starter only has 2 wires though, a big one and a smaller one.
Related Topics
Thread Thread Starter Forum Replies Last Post
Please help!!!!, starter?? driftpinto General Maintenance & Repairs 7 01-16-2015 07:59 AM
'63 chevy ii starter/starting issues Racinjason424 Conversions & Hybrids 6 08-26-2014 03:23 PM
ls6 miata starting issues orion4096 Conversions & Hybrids 18 02-18-2013 07:04 PM
Looking for LS1 Experts bartrman Generation IV Internal Engine 8 06-05-2012 01:50 PM
SBC Problem LS1Z28_98 Small Block & Big Block Chevy Specific 7 11-03-2008 10:46 AM
Tags
bad, car, crank, fuel, g8, gring, hot, pontiac, problem, regulator, start, starter, symptoms, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
