Front end
Front end
Bought a 2001 ws6 off of here bout a mnth ago have a slight problem I'm trying to figure out need some suggestions k da car sits low in da front on da driver side only changed da shock out and and spring out and it still sits da same way now da car does have a iron block with all stock suspension any suggestions : thanks
You sir, need a swift shot of chill the **** out. My suggestion would be to change out the springs, if that doesnt work, you may have a major issue.
Your first post should have read like this.......
Hey guys,
I bought a 2001 ws6 off of here about a month ago. I have a slight problem, I'm trying to figure out and need some suggestions. My car sits low in the front, on the driver side. I changed the shock and spring out, however and it still sits the same way as before. The car does have a iron block with all stock suspension. Do you have any suggestions? : thanks
See how easy that was........****!
