what is this called?
the motor i'm swapping has been sitting for a while & i'm trying to change out as many parts as i can. i sent my injectors off to get bench cleaned & want to know the technical name for this part so i can replace it, if possible.
It is a fuel pulse dampener. The fuel pressure regulator is in the tank on the fuel pump sender (great idea). I'm not sure if its replaceable or not, judging by the snap ring , I would think you could change it, but I'm not sure.
Did some snooping. I guessing you can change it. https://ls1tech.com/forums/generatio...first-try.html
yeah its the same proceedure as when it was a fuel pressure regulator.... its a fairly unnecesary peice- when they put the regulartor in the tank and they didnt need a regulator on the rail anymore- had tens of thousands of fuel rails made up so they stuck a pulsator in it so they had somthing to plug it up...
