cam help
cam help
I'm just looking for advice on a cam.My car is a pretty much stock 2000 trans am non ws6 with the t56, slp airbox,loudmouth exhaust and a spec 2 clutch.I'm looking for something good mostly on the low end I'm not going to be shifting at 6500 or anything like that.I would like to be as close to 400hp to the ground as possible without spraying,also I don't mind noise honestly the louder and angrier the better any advice is appreciated thanks.
Do yourself a favor and get some lt's, ory and possibly a ls6 intake first before you do a cam. Whats the point in having a cam if it can't breath? But anyway you would want something around the 230 range, but even then you will still rev past 6000
Your not going to hit 400rwhp with just a cam. You need some supporting mods to help get you there. Even then you may still not get 400. But you will be damn close
I was planning on a tune and headers as well just not sure the right way to go about it I guess.Will I need to get a tune after just adding an intake or would it be best to wait until after a cam?
Check out some of the sponsors for headers. Don't waste your time with shorty headers or mid-lenghts. Get yourself some long tubes and be done with it. Lt's will net you the most hp. If your on a budget, get some armor coated Pacesetter's. If you have a lot of money to drop, then shoot for some stainless steel headers.
Better yet, read this! https://ls1tech.com/forums/new-ls1-o...anna-fast.html
