Motor swap crank no start
98 camaro, lq9 swap, tfs225, 102 setup
The motor started for a little bit maybe 5 seconds tops and then it was just off to button up other little loose ends.
Now the engine spins over but will no start. It appears I have fuel pressure unknown actual will know tomorrow. 3 grounds on driver head tight, has spark.
Is there anything that is common for this vats maybe
Well I have 55 psi at the rail, it is a injector issue. The injectors are not pulsing, have 12 volts battery voltage on all the pink wires for injectors just not seeing ground thur the PCM. When cranking the security light comes on solid and no fuel. So I will be deleting that **** later to night it will start on brake clean
Sounds like Vats to me... But if you just swapped longblock that alone shouldn't cause a Vats problem. Is it throwing any DTC's? Have you changed the PCM? And check cam and crank signals...
