General LSX Automobile Discussion Non-technical LSX related topics.
is it worth it? 5.3 build
Old 12-29-2011, 12:06 AM
robster's Avatar
Default is it worth it? 5.3 build
need some help. what could i expect with taking a 5.3, bore it to a 5.7, using stock 5.7 crank roads and pistons, 243 heads, ls6 intake, cam.....is it worth doing?
Old 12-29-2011, 12:07 AM
robster's Avatar
custom cam that is
Old 12-29-2011, 10:07 AM
ryant13's Avatar
Depends on your goals. The 5.3 itself can be made awfully powerful by itself. How much are you going to be charged for the machine work?
Old 12-29-2011, 10:09 AM
ChevyThunder17's Avatar
Could be worth it, depends on cost. Are you planning on doing forced induction down the road?
Old 12-29-2011, 04:32 PM
robster's Avatar
eventually ill do forced induction. just wanted to be sure that its still gonna be worth building. like if i get it bored to a 5.7, it should be the same as a 5.7 block, correct?
Old 12-29-2011, 04:37 PM
robster's Avatar
and the machine shop is charging 200
Old 12-29-2011, 05:05 PM
NVUSZ28's Avatar
I'd keep it a 5.3. You can make a LOT of power with the 5.3's. Sure, there's no replacement for displacement, but $$ wise. Just my .02¢
Old 12-29-2011, 06:20 PM
zracer323's Avatar
If you are building it for boost then I would keep a 5.3. If you can get the machine work cheap it may he worth it to make it a 5.7
Old 12-29-2011, 06:50 PM
As has been already said, I'd also keep it as a 5.3. Those thick cylinder walls are in your favor, and I don't know you'll really miss the .4 liters when you are jamming air in it.
Old 12-30-2011, 12:12 PM
robster's Avatar
but what about before boost. will the 5.3 with 243 heads, custom cam, ls6 intake, and long tubes still make as much power as the same set up except with a 5.7?
Old 12-30-2011, 12:40 PM
1lejohn's Avatar
It should make the same power. I would think it would be within 3-5% of the larger engine. It's only about 20 cubes so you might be down 10-20 lbft. If that much.
Old 12-30-2011, 12:42 PM
SHRIKE427's Avatar
So,.. What kind of HP numbers are you guys seeing with a warmed over 5.3??... No heads, just a cam, cold air set up, rollers maybe??...
Quick Reply: is it worth it? 5.3 build
