K&N or SLP CAI?
K&N or SLP CAI?
Just bought a 98 TA LS1 and trying to decide which cai intake to go with. i heard the slp was rated at more hp gain but sometime had problems with fitting correctly. but i have heard good and bad things about, was hopig to get some input from people that actaually own these parts.
Not a fan of the K&N intake and I dont like SLP for mostly anything as I think its all overpriced. Look into the Fast toys ram air, Chris1313 (Speed Inc has them on their site), or the Super Sucker Ram Air. WS6store has the SSRA. Any of these 3 are good viable option. I also would look into a different lid if you still have the stock one. SLP is good I had one, it fit pretty good and if your going to keep you MAF I'd say go with that one. If your going to be going with a larger MAF or thinking of going speed density check out the larger lids by Fast Toys.
Ya ive been lookinig into them. ive only had the car for 2 weeks. so a different lid and maybe k&n filter? how exactly does the lid help? just looks like the black plastic one the ls1 comes with? i dont have a ram air hood either. idk if that makes a difference. sorry for all the questions just trying to find out what is the best parts to use for now
The aftermarket lids do not have those big sections that reduce your air speed. Ram air is not really that effective on these cars, so your moving in the right direction with a CAI.
Get yourself a SLP lid and one of the CAI I mentioned and you will see a nice gain.
Don't forget to check the classifieds for a good deal on a lid.
Your fine with asking questions just don't forget about the search function, almost everything you can think of has been answered several times over in here.
okay what about water being sucked into the ram air?? i daily drive this car and want to be able to drive it no matter if its raining or theres a puddle i have to go through
With an SSRA/CAI there could be a little bit of a problem, but that's what the air dam is there for.
Ditto on what My6speedZ said about a place to start. For the money a lid, MAF, Filter and a CAI or SSRA you'll feel noticeable gains. Also for first time upgrades I'd buy a set of MSD wires, and a ASP Underdrive pulley. These are your normal "bolt-ons" minus headers and exhaust. You can also do some free mods, like AIR delete.
Here's a thread about the SSRA my friend posted.
https://ls1tech.com/forums/general-l...ions-pics.html
http://www.installuniversity.com/ins...sity/index.htm
QUOTE=TAkid23;15794241]
so if you had 300 or less to spend on a cai or different lid/k&n filter or something what would you do?[/QUOTE]
Buy a decent Lid, a regular paper filter and either Chris's setup or Fast Toys ram Air. Stay away from the Clear lids. they are crap and are prome to cracking.
My friend has the K&N on his Trans Am, totally not worth the $300 or whatever the ridiculous price is on those things. I would just buy a regular lid, then do one of the free intake mods. That way you will be outflowing the K&N by a longshot and doing so at almost half the price.
not necessarily, the K&N flows extremely well, it just pulls hot engine compartment air. the reason its not worth the 300+ dollars for it is because in order for the &/hp ratio to be on par or better than a lid/FTRA..ect...you have to modify it to have a path to direct outside air. which in my opinion, is pointless. i have a hard time spending that kind of money on something I have to modify to make it work as well as something half the price.
also, if you have a WS6 hood, and dead set on something other than a lid setup, the Voliant setup is the best. it actually seals to the hood, and I have seen good gains by de-baffling the WS6 hood and mating it to a Voliant CAI setup. It is bulky and kinda cheap looking but it works pretty good.
http://www.lmperformance.com/2387/.html
Moderator
SLP CAI gets real hot next to the radiator and it raised
my IAT readings by a couple tens of degrees when added
to the stock SS setup. Any "ramming" is trivial, forget it.
If you seal across the top of the radiator support so the
lid can't draw engine bay air, and relieve the air path into
the space above the divider panel (black plastic in front
of the radiator space), there is cool air there. This is
what the K&N FIPK tries to do, only I'm not convinced
the baffle-plate is all that effective (could be modded
of course).
I'd get a used lid and forget retail.
of course).
