Slp hood
Slp hood
I have an slp H.O hood for my trans am. I notice it does not have the rivets at the bottom like the original ws6 hood where you can remove those Lil plates and get more air flow thru the vents if anyone has done this mod your help would be much appreciated !!!!!!
I'm not sure what you meant by the detail comment. But for one if you are trying to get more air into the motor, taking those grills out doesn't really help. The "ram air" effect doesn't really take place there until well over 100mph. If you actually want to increase performance look into one of the actual ram air kits, such as the CHRIS1313, or even make your own.
And just a bit of advice on using this forum. If you want people to help you with a solution to a problem, I would suggest you not antagonize them by being a smartass when they post a response in your thread. A little common courtesy will go a long way "bro".
