confussion...need help
ok, i've been reading a little here and there on mods versus power in the 5.3 and 6.0(lq4) and trying to take pricing into consideration as well. i want opinions from you guys, my power goals are 450-500 to the wheels, with good street manors and i dont want some crazy setup that i have to rev teh **** out of to see power. i just want to see a starting point so i can see which engine money is going into. any advicxe would be helpful.
thanks in advance
thanks in advance
I haven't done enough research on the 5.3L but if you can find a well priced LQ4, for about 2-3g's total you can easily hit your HP range. Heads/intake/cam/headers should put you there with a good tune. All depends on what deals you can find at the time you go to buy everything, some guys here have done it with less $$.
What's the motor going in to? If you are swapping in to your LT car, in the long run it's probably going to be cheaper to build an LS1/LS6 that already has the f-body pan, LS6 intake and f-body accessory drive.
