OEM Exhaust Hanger Problem
I have a problem with the drivers side exhaust hanger... it's driving me nuts! I can't do any spirited driving without the catback coming loose from the rear driver's side hanger... I launched it today and it came out The insulator and bracket are fine... it's just the piece of metal welded to the pipe keeps slipping out of the insulator. Extremely inconvenient. I'm drawing a blank on a fix that is quick yet not too "ghetto", tools are limited. I was thinking about a whole new hanger... possibly this one (if it fits/works with a stock catback???)
http://www.summitracing.com/parts/WLK-36314
If anyone else has had this problem, if there's anything I can do that's simpler than a whole new hanger to fix this, please let me know!
1 Post
It's kinda hard to tell what your talking about without seeing something. It sounds like you could just fasten something on the bolt so it wouldnt come out, a tack weld would stop it and you could easily grind that down later.
I'll take a picture a.s.a.p. but I'll try to explain it again... I'm sure you're aware that there is a small metal rod welded to the tail pipe on the drivers side that also fits in the rubber insulator. That part keeps slipping out of the insulator. I wish I had a welder... as I stated I'm limited on tools at the moment :/
Guess this picture will do for now...
Bottom part of the hanger (the rusted metal part in this picture) keeps slipping out of the insulator... see what I mean?
that rusty hanger should have a bulge on the end to keep it from slipping out or be bent down on the end to keep it from slipping out cant really tell if it has either from the pic
It doesn't... very stupid design. I wish it would've at least been bent upwards or designed in a way that it wouldn't slip out so easily. Maybe a better designed insulator will work?
Yea that sounds like a good idea... I was just hoping someone had a quick fix idea. Thanks though! Might consider this if I don't find a DIY alternative.
I presume it's an aftermarket exhaust since the hanger doesn't have the little ***** head thing to keep it from sliding out. Any exhaust shop worth a **** would weld a bead on it or heat and bend it for free...would take 3 min and would be a good business move on their part.
For an at home fix, my best idea would be, if there is enough of the hanger sticking through the rubber isolator, buy a small u-bolt clamp that the end of the hanger just barely fits through and tighten down both nuts to keep the hanger from pulling back through...same as welding on a bead, but easily removed.
Yeah, the stock (and most aftermarket) hangers are mushroomed on the tip so they don't pull out. Even if you just had a decent propane torch and a hammer you could mushroom it yourself (keep in mind there is a gas tank back there). I would say u-bolt for the quick and easy at home fix...couldn't take more than $3 and a 5/16 wrench
take a fender washer (oversized) and cut it thru on one side , take 2 pair of pliers and open the slit so it fits over the rod hanger and then twist it back into its original shape and your fixed.. oldman...
Hah.. maybe if all else fails. Definitely not an oldman.
I'm glad this was brought up. I have an aftermarket catback on my car as well and it does the same thing. I thought maybe I didn't have everything lined up correctly and that's why it keeps popping out. I will have to give the ubolt thing a shot.
Very poorly designed
