miss fire questions
miss fire questions
i got 99 t/a full bolt on's i hit the car with spray not too long ago, and now im getting p0300 miss fire code. car misses at idle and part throttle cruising i get on the gas a lil and it goes away.
looked at spark plugs and they look ok, changed the wires don't know what else to look at they say weak fuel pump can cause this or fuel regulator ? what about fuel filter ? i doubt its a coil or injector cus the miss is all over the place looked at live data and i got all 8 missing. if it would be a coil or injector it would be one 1 or 2 right ?
need some help car sounds like **** and its chugging gas like never before.
thanks in advanced
thanks in advanced
Im on the mobile site so I cant see your sig. Does the car still have cats? If it does one of them could be clogged. Is the nitrous dry/wet and how big of a shot are you spraying. What plugs are you using? I'm just gonna guess and say your 02 sensors are screwed up. I've heard and experienced that N2O tends to wear them out pretty quick especially if your tune is on the rich side of things.
thanks so that's most probably whats going on then. i was a lil worried cuz to tell u the truth i was trying to blow the motor that night. cuz of my uncle told me if i blew it he was getting me a 6.0. i ran it with the predator tuner with timing advanced and leaned out and no boom. i did have a richer fuel side im going to try on my brothers o2s and see if it gets better thanks for the help.
the tr6s are the one's i seen everyone run on 100 shot. they say the br7s are for 150 range correct me if im wrong. im looking to go 175 200 when i tune
i also went with a th350 tranny brake and i haven't tuned for it either so i don't know whats triggering that misfire
ok guys i swapped out the o2s and the o2 codes went away. the car it driving normal at part throttle but still feel a little miss at idle. cables are new plugs look ok abut 3500 miles on the plugs. what else do u guy think i should look at?
thanks for the help so far
