Installed Magnaflow high flow cats lost power
Is it possibloe that I need to get the car retune after installing the magnaflow high flow cats I lost huge power I use to floor it a 20kmh and just couldn't keep it straight it spun through 1st and second now it just hooks and go.
My butt dyno is telling me that I lost 1/2 of what I gained. I was just wondering if anyone has experienced the same thing. My car doesn't smell like gas no raspiness at all from the exhaust but major power lost....It feels like I lost 1/2 of what I gained and I had a 50rwhp gain
Is it the can't have your cake and eat it 2 syndrom here would cats because of back pressure make the car run richer hence loose power .I will call my tuner and get it back on the dyno to check kit It does drive like I have just a cat back great on the ears :-)
LS1Tech Administrator
Received 1,488 Likes
You added a restriction to your exhaust system, hence you will lose a bit of power. A "high flow" cat doesn't mean it will ever flow as well as a straight pipe.
Having said that, you should never lose 25rwhp (half of what you said you gained) just by adding high flow cats to a cam + bolt-ons car, although it's possibile that the combo of adding the restriction of the cats plus whatever effect it may have had on your previous custom tune might have resulted in a noticeable net power loss over the ORY.
If you just want to reduce rasp, I'd use bullet muffers in the Y-pipe rather than cats. Only purpose for cats would be if you need them to pass emissions.
Ok
Hum good point
I am tired .... headers valve noise amazing when you modifie what you have to go through I hope the finish product is worth all the effort
This is amazing to me, that you could perceive it this way. I've taken cats on and off (both stock and aftermarket high flows) of various setups, and the difference in sound is always striking....I mean there is NO question for me that the tone and volume has changed significantly.
