You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
thanks for the responses guys. How accurate will it be with trans temp vs a single trans gauge in the transmission?
Reading from your obd port for trans will read lower than aftermarket gauge acording to some sponsors.
Quote:
Originally Posted by mjs1012
What is the benefit of monitoring the o2 sensors?
To make sure they oscillate like they should.
Quote:
Originally Posted by ripgtp97
Can anybody confirm the installation of this gauge? If you just plug the main connection into the odb2 port won't It always have power? Do you need to run that 3 wire connection to a switch power line?
I dont really know what wire your talking about. Mine was plug in the obd and good to go.
Quote:
Originally Posted by mikey67
I had to run power to mine in my '98 Trans Am, as I recall later models don't need this? Check the Aeroforce forum if it's still active.
These are the instructions I found off of another site.. It's talking about extra wires to hook up from 0-5 volt sources for other parameters and also that center red wire for a possible switch power because the obd2 port has power to it at all times? I don't really know.. if anyone else has experience with this, please chime in!
__________________
2000 Trans Am A4 3.73 gears 334/338
BBK Longtubes/ORY | Loudmouth II | P&P TB & Smooth Bellow| LS6 Intake | MTI Lid | 25% SLP UD | Bilstein's/Eibach Pro | BMR STB | UMI Subframes | UMI Panhard | Founder's LCAs | Richmond 3.73's | Tuned by Slowhawk
13.3 @ 106.82 with 2.73's
13.1 @ 107.84 with 3.73's (terrible track conditions)
hmm okay I wonder what years require the extra wire.. seems like 98 def does, and 2001 doesn't. I have a 2000 if anybody happens to know when they changed it?
__________________
i have my gauge all set up but sometimes it doesnt turn on when i turn the ignition or car on. could this be because i have a 98 and have to hard wire it? its currently just plugged into the obd port and reads everything
I've had mine for over 5 years and it has been in 2 different cars. Great guys to deal with also, I had it reflashed to work with my SS after I sold the car it was originally in.
