Oil pressure gauge
Oil pressure gauge
Having Oil pressure gauge problem heres whats happening i start up car Oil pressure is at The first line and then drops to 0psi and on dash it says check gauges but motor sounds fine
LS1Tech Administrator
Received 1,489 Likes
Either you need a new sending unit, or you really have lost all oil pressure. You could verify with a mechanical gauge, or just replace the sending unit behind the intake.
