Possible to change mileage odometer on the TITLE? Details inside. - LS1TECH
General LSX Automobile Discussion Non-technical LSX related topics.
Thread Tools Search this Thread
Old 06-30-2012, 11:53 PM   #1
Default Possible to change mileage odometer on the TITLE? Details inside.
First post on this site:
Ok so I had my car serviced at a GM manufacturer and had a 4.10 rear end put in. They wrote down the original miles when they installed it. I drove it for years like this and (speedometer off as well) and just last month I bought a predator to correct the speedometer error. Well I went back to GM and they did calculations and said my car read 11,008 miles more than it should have because of this higher rear end ratio. So they reset it back to what it should of actually been for me. My concern is, when I moved states and took the car with me I re-did the title and gave them the odometer mileage. Now at 56,219 GM reset the mileage to 45,211. So that leads to my question:
is it possible to send off and have the people on the title change to show that the actual mileage is not the 54,xxx miles (mileage 4 months ago that they put down when I moved states) but that it rather is only 45,211 miles as of today....
emanxxx is offline   Reply With Quote
Old 07-01-2012, 12:16 AM   #2
parks450's Avatar
Yes you can have them change it. You have to contact the secretary of state
parks450 is offline   Reply With Quote
Old 07-01-2012, 02:51 AM   #3
Quote:
Awesome, now next question. How do I go about proving to them that that is my new mileage? Submit a picture? Take it somewhere in person?
Thanks!
Old 07-01-2012, 11:04 AM   #4
NC01TA's Avatar
Documentation will be required for each step, from the GM place to the final inspection when someone actually comes out to your home to see the car. Paperwork, paperwork, paperwork when it comes to this stuff. It will cost money too. DMVs charge for everything. I've had it done on an older car in FL and the process was the same here in NC for a car collector neighbor of mine. In both instances it was just a wrong number put on the title yet it required the personal visit from an inspector. Too much fraud involved which is why most states consider it a felony to manipulate mileage. You can get it done but expect some time consuming efforts.
NC01TA is offline   Reply With Quote
Old 07-01-2012, 02:07 PM   #5
Fry_'s Avatar
Unless you plan to sell the car some time soon I would't bother, sounds like more trouble than its worth.
Fry_ is offline   Reply With Quote
Old 07-01-2012, 05:15 PM   #6
how much do you drive the car? if you drive the car say 7000 miles a year, why dont you just add only 2000-3000 to what the title says.....eventually you will get yourself cought up
Floorman279 is offline   Reply With Quote
Old 07-01-2012, 05:15 PM   #7
that is if you are going to keep the car for afew more years
Old 07-02-2012, 12:14 PM   #8
udienow's Avatar
Do post back if you get the title fixed. I am curious exactly how much pain in the *** it will be. I am in a similar boat... i changed to 4.10s but havnt fixed my speedo yet. But i've only put on about 1k miles so its not off by much... def not worth it for me unless its way ez.
udienow is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Reset replacement instrument cluster odometer to HIGHER miles? eb2phkingood General Maintenance & Repairs 22 06-28-2012 01:14 AM
Need Info on Resetting Mileage on C5 DIC quadman Corvette Performance 1 04-07-2011 12:00 AM
Speedo not working, VSS replaced, still not working White.Lightning Eastern Members 7 11-12-2010 07:17 AM
Changing odometer (not trying to be illegal) jpticar Appearance & Detailing 8 01-18-2007 07:36 AM
how to interpret this carfax report? narc Racer's Lounge 3 03-07-2006 07:32 AM
Tags
410, add, car, change, changed, grong, mileage, miles, milles, number, odometer, put, reset, tile, title, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
