bbk underdrive pully help - LS1TECH
General LSX Automobile Discussion Non-technical LSX related topics.
Thread Tools Search this Thread
Old 10-01-2012, 04:45 AM   #1
Default bbk underdrive pully help
Ok i have searched an all i can find is on lt1's. I have a 2000 ls1 camaro. I purchased a bbk underdrive pulley kit, it stated that it would work with factory belts, well it doesn't on mine. What belts do i need? Also how do i know for sure that the pulley is all the way on? It looks to be in line an i have torqued it down to 45 ft. lbs.any an all info much appreciated. Thanks in advance.
stherngent is offline   Reply With Quote
Old 10-01-2012, 08:25 AM   #2
Welcome to the world of getting to know your Napa dealer. All you can do is take down your old belt and get one a little longer shorter then what you have, as long as you have the sleeve that the belt comes in it is not usually an issue to return so pick up a couple of different lengths to find out which one works best.
Do you have a manual tensioner, then wrap the belt. let it have some flex and then start the motor, let it run turn off and check.
Orange Juice is offline   Reply With Quote
Old 10-01-2012, 08:32 AM   #3
Maybe when they wrote "ALL BBK performance under drive pulley kits use existing factory serpentine belts", they were talking about the style, and not the length? You wanted more available HP via pulley, so it stands to reason that a part with a smaller radius/diameter/circumference won't need an OEM length belt.
http://www.bbkperformance.com/download_file.php?pvk=534
Quote:
NOTE; INSTALLATION OF THIS KIT REQUIRES THE FOLLOWING-
(1)77 6 RIB BELT,
(1) 37.7 4 RIB BELT,
Somebody09 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
bbk underdrive pulley owners come in! Sail Hatan Generation III External Engine 7 01-16-2013 09:19 PM
Underdrive pulley and belt TIIMuch Parts Classifieds 0 09-26-2011 04:26 PM
Asp pulley belt? 69blackwhss Generation III External Engine 2 08-30-2011 02:51 AM
BBK Underdrive Pulley - Which belt? Roxas Generation III External Engine 4 08-04-2011 02:09 AM
What size belt for march underdrive crank pulley? Quick94LT1 LT1-LT4 Modifications 5 02-26-2011 12:41 PM
Tags
2000, bbk, belt, camaro, drive, gaa, gains, leaking, ls1, lt1, pulley, pulleys, size, underdrive, undrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
