General LSX Automobile Discussion Non-technical LSX related topics.
How to make 550-600 rwhp from LS1
Old 12-11-2012, 06:30 PM
camoffett's Avatar
Default How to make 550-600 rwhp from LS1
I'm new to the forum and ls world. I recently bought a 69 camaro that I am building a pro touring car out of. The car came with a rebuilt LS1 from a 99 Z28. It has a stock bottom end with 243 heads, torquer V2 cam, and LS6 intake. I have a complete chassis works suspension with a fab9 true trac rear end and a 4L80E trans for the car.
Question is: What is the best way to get the power I'm looking with my current setup? Goal is 550-600 rwhp.
1. Do I buy a turbo and a 383 stroker kit?
2. Can I buy a stroked LS3 short block and use my current top end?
3. Do I sell the whole motor and start from scratch?
Ideally I would like a 427 or at a minimum a 383. I want this to be a streetable car without using NOS.
Any help or suggestons would be appreciated.
Old 12-11-2012, 06:37 PM
redtan's Avatar
You're going to need some serious cubes and top end to pull that kind of power naturally aspirated.
Your best bet is a basic forged 347 with a turbo. It will be tough to get to your goals with anything under a 418, and if you do get there it will be a very non-streetable setup.
Old 12-11-2012, 06:39 PM
zracer323's Avatar
A budget friendly setup would be an iron 6.0L with a turbo. Can easily make 550rwhp. Many have done this successfully.
Old 12-11-2012, 06:40 PM
babbage1109's Avatar
Throw a procharger on it.
Old 12-11-2012, 07:44 PM
senicalj4579's Avatar
forced induction with whatever motor you end up using
Old 12-11-2012, 07:45 PM
Orange Juice's Avatar
I'm hoping to be close to the 600 rear wheel with the addition of the 102 intake, better exhaust and a vacum pump with a mafless tune. The headers might hold it back.
Old 12-11-2012, 08:48 PM
camoffett's Avatar
Thanks for the replies. So if I was to go FI with a stroker kit, what turbo setup would be best? Procharger?
Is there a good site sponsor to discuss this with?
Old 12-12-2012, 06:52 AM
Most sponsors would be able to point in the right direction. AES was building a short block designed for boost and I'm sure others must also. Check out the forced induction section if that is the way you want to go.
Old 12-12-2012, 09:19 AM
There is a guy in indy with a stock bottom end ls1 and an f1 procharger making 624 hp on 8 pounds of boost. But I would highly suggest getting a forged bottom end if you plan on making any reliable power
Old 12-12-2012, 10:13 AM
I would think that if you wanted to use your heads and intake then forced induction is the only way to go. Going to a NA 427 would require pretty much everything new except for the front cover and oil pan.
But, for some NA is the only choice.
Old 12-12-2012, 02:19 PM
why87's Avatar
A decently cubed forged motor on spray would work as well.
Old 12-12-2012, 06:23 PM
01 CamaroSS SLP's Avatar
A procharger on top of the mods you have should give you your HP goal.
Old 12-13-2012, 06:54 AM
Camaro_94's Avatar
Turbo/supercharger/nitrous... With a stock bottom end LS1 should get you there... However if you have the extra money to build up the short block it wouldn't be a bad idea to do that though.
I have a cam/head/nitrous setup (only a 100 shot) on my Z06 and it makes 540rwhp/590rwtq on spray. You won't get 550rwhp NA on stock cubes though.
Old 12-13-2012, 11:02 AM
A.R. Shale Targa's Avatar
Since you already have a decent LS1 combo and don't want to spray, big
cube NA will also be BIG coin, I'd consider a budget turbo set-up...The Borg-
Warner S475 is only $6-$700 range and can be had with a .96 ar for quicker
spooling. You could put in some 80lb injectors and safely run 10lbs of boost
on E85 fuel....easily eclipsing your 550 mark....closer to the 600 rwhp. No
fancy headers...just 6.0 manifolds backwards and E-bay tubing to save a few
bucks.....
Old 12-16-2012, 10:18 PM
prokilllsx's Avatar
Your setup, supercharged with 5 or 6 lbs of boost should get you there and if tuned properly should be dependable. If it lets loose one day, then build or buy a forged bottom end in bigger cubes if you prefer and throw serious boost at it.
Old 12-17-2012, 09:18 AM
bayer-z28's Avatar
Turbo, Procharger or a lot of spray.. It takes a lot of money and a well designed plan to get 500rw out of a h/c LS1.
Otherwise, see the bible:
https://ls1tech.com/forums/generatio...heads-cam.html
Old 12-17-2012, 12:27 PM
R6cowboy's Avatar
You say you ideally want 383 cubes and no N2O. This is very simply answered to get at least 600whp. A nice forged 383 stroker assembly for your current LS1 with reverse dome pistons to add some cc's to lower the compression suitable for boost. Then add whatever turbo or supercharger setup that suits your liking. This will very easily give you 600whp without a sweat and be very streetable and reliable for long time.
Old 12-17-2012, 03:01 PM
bayer-z28's Avatar
^ 390's actually handle boost like a champ. Different pistons. Thicker ring lands.
Old 12-18-2012, 07:34 PM
Sierra Speed Shop's Avatar
I think we have what you are looking for. We offer Edelbrock Longblocks, much cheaper then what is listed on their website.
Every Edelbrock assembled engine is backed by a 2 year unlimited mileage warranty.
This particular set up is equipped with the e-force supercharger. You can also buy the whole engine complete with a wiring harness and accessories.
Please click here to learn more!
Feel free to call and ask questions. We are also available via e-mail.
Old 12-19-2012, 10:10 AM
willizm's Avatar
I'm with everyone else. You'll need a power adder to get there. Do H/C/I and throw a 100 shot on it. Else you'll need to go FI or find yourself the worlds happiest dyno.
Quick Reply: How to make 550-600 rwhp from LS1
