General LSX Automobile Discussion Non-technical LSX related topics.
Driving to tuner after gear swap?
Old 03-22-2013, 11:29 AM
RPK250's Avatar
Default Driving to tuner after gear swap?
I swapped rear ends and went from a 2.73 gear to a 3.42 gear in an A4 car. I have to get the car about 20 miles to the tuner. I'm wondering if its going to be possible to drive the car there, if i shift manually, without a lot of crazy downshifting going on.
Old 03-22-2013, 11:33 AM
cj92345's Avatar
i did'nt change anything after gear swap other than speedo cali with a cheap programer
Old 03-22-2013, 11:43 AM
R6cowboy's Avatar
You can drive the car to South America and it won't hurt a thing other then your speedometer won't be correct. Like cj92345 said all that's needed is an inexpensive speedo re-calibration.
Old 03-22-2013, 12:28 PM
RPK250's Avatar
I know that's true for a manual, but i thought the shift points needed to be changed on an auto.
Old 03-22-2013, 07:01 PM
1320Chicken's Avatar
The shift points will be off because the speedo is off. You can drive it wherever you want I just wouldn't beat on it.
The computer needs to see the desired shift rpm and mph before it will shift.
Old 03-22-2013, 07:32 PM
ULTIMATEORANGESS's Avatar
Smile
youll be fine though i wouldnt manually shift it too much.
Old 03-24-2013, 08:03 PM
deez01ls1's Avatar
I swapped my a4 from 273-373....and drove it 45 miles to my tuner....yes shift points and speedo were off...just dont beat on it...you should be fine
Quick Reply: Driving to tuner after gear swap?
