General LSX Automobile Discussion Non-technical LSX related topics.
Stock upper A arm Ball joints replaceable.
Old 04-26-2013, 03:38 PM
qwkhuh's Avatar
Default Stock upper A arm Ball joints replaceable.
Hello not sure i this is the right location for this question but i have a 00 trans am and need to replace one of the upper A arm ball joints my question is do i need to replace the hole control arm or can i just replace the ball joint it self? some people say that it can not be done figure i would get some in put on this. any info would be greatly appriciated.
Old 04-26-2013, 06:28 PM
HoLLo's Avatar
This would go in the Suspension & Brakes section, but you don't have to replace the whole A-arm, you just need a ball joint press which you can rent from any parts store.
Old 04-26-2013, 07:45 PM
1320Chicken's Avatar
Uppers are rivited in factory. The replacements will come with bolts. Grind the rivits off and bolt the new ball joints in.
Old 04-26-2013, 08:22 PM
birner88's Avatar
Yep either grind or use an air chisel on the rivets press out and put in the new ones.
Old 04-27-2013, 10:59 PM
99Bluz28's Avatar
I'd stick with a 1 piece sealed factory like ball-joint if possible.
Old 04-30-2013, 11:35 AM
scottyroc's Avatar
Rent the ball joint press from an Advance if possible since I rented one from AZ first which was a smaller kit and didn't have as many adapters. The right tool makes every job easier.
Old 04-30-2013, 12:48 PM
99Bluz28's Avatar
You don't use/need a press for the upper ball joints, they're riveted in place.
So as already stated just cut/grind/chisel the rivet heads off, then bolt the new ball joints in place.
Quick Reply: Stock upper A arm Ball joints replaceable.
