General LSX Automobile Discussion Non-technical LSX related topics.
which ls engine is better for twin turbo?
Old 07-02-2013, 04:47 PM
Carterboi05's Avatar
Default which ls engine is better for twin turbo?
Im planning a ls swap but dont know which engine to go with cause i want to twin turbo it.
Old 07-03-2013, 11:07 AM
redtan's Avatar
Can't go wrong with either a 4.8, 5.3 or 6.0 low comp iron block.
The 4.8 will be the most reliable, while obviously the 6.0 will make more power on the same boost levels.
Old 07-03-2013, 08:55 PM
Blackpanther99's Avatar
Indeed^^ Either will get the job done.
What are your goals?
Old 07-11-2013, 07:51 PM
Transam9973's Avatar
6.0 lq4 or lq9 for reliable power both have fairly low compression ratios
Old 07-20-2013, 11:53 AM
blue89irocz's Avatar
Is the only difference between the LQ and LS motors iron and aluminum blocks? I am looking to also build a turbo motor for a third gen so Im curious
Old 07-20-2013, 11:56 AM
Also would it be wise to buy a complete motor or just buy short block and build up. Not sure how heads flow or are aftermarket better?
Old 07-21-2013, 08:11 AM
A.R. Shale Targa's Avatar
You could get in good with the fellas @ Speed Inc.; They have done every
possible turbo combo. Jim Moran who tuned my Vette has a pair of GN twins
on an LQ9 in a plain black 70 Malibu...thing is quiet and runs like mid tens.
I believe he has worked there for quite a long time.
Old 07-22-2013, 05:39 PM
zracer323's Avatar
How much power are you trying to make and what is your budget. It's impossible to answer your questions without knowing these two things.
Old 07-22-2013, 07:27 PM
LS-ONE_DAY's Avatar
I'd say a 5.3 or 6.0 iron block. Yes the LQ are the iron truck blocks...99% sure that is the major material difference between the LQ and LS
Old 08-02-2013, 01:17 AM
bears416's Avatar
4.8s have been proven to laugh at stupid amounts of boost stock and are a dime a dozen im bettin a 4.8 in youre case would be a good route
Old 08-02-2013, 07:23 PM
OP never came back in... Lol
Quick Reply: which ls engine is better for twin turbo?
