pcv hose where can i get?
Sold in Thermoid boxes on the rack labeled as "crankcase ventilation hose" or "vacuum hose". Use either of those since if it's not labeled as such it might collapse under vacuum, or make sure if you ask the counter jockey for vacuum hose he actually gives you vacuum hose and not just hose.
Just whatever size will fit. Once you have the valve you can just open the boxes and find what fits. The stuff in the boxes is always odd sizes like 15/64" instead of 1/4" etc probably so it fits tight on barbs. Don't know about our cars but on most I reckon whatever is closest to 3/8" usually works.
thanks guys!!! one more thing i noticed since the leak i was having trouble with starting it when cool and after second try it would start think that was contributing to the problem but i changed the vaccum hose and it did it again any help ?
