ls1 engine removal from top of f-body
Hello, my husband wants to pull our ls1 from the top and was wondering if he unbolts the t-56 bellhousing from the motor would he be able to pull it???
He didn't know if the tranny would have to be slid back or not?
everything is gutted in the engine bay now and it's just a shortblock. All of the accessories have already been removed and everything unplugged.
We are hoping we don't have to unbolt anything else from the tranny to just remove the engine.Thanks in advance.Jennifer
I pulled my stripped shortblock from the top of my camaro, but i had the drive shaft unbolted and the trans slid backwards....not sure if you will have enough room to slide the motor forward off of the input shaft and then lift it out. I'd say you will probably be okay as long as the radiator is removed.
We do have the radiator and all that removed as well. It just seems as the motor would have to be lifted 4 or 5 inches then slid forward so the oil pan clears the crossmember.
How far would you say the motor needs to be seperated from the bellhousing for the input shaft to be out?
Doing it the hard way huh? You will need to remove the intake in order to get the motor out from top. I just did a motor/tranny , front k member & suspension removal all as 1 assembly. Swapped from 1 car to another and put the other one back, in about 8hrs ,all by myself, through the bottom of the car. All I had was a motor hoist , jack and jack stands. No problem.
We pulled the motor from my transam through the top, t56 still attached. It was just a shortblock, no accessories on the block not even the crank pulley. came out pretty easily with the hood off actually.
pulling from top
I did mine out the top with no trouble. I just disconnected the transmission and took all accessories off including the radiator. I already had the heads and intake off when I pulled it.
I left the tranmission in and pulled the engine from the top, I did not even undo the driveshaft or the tranny crossmember, I stripped the engine to the shortblock, pulled radiator and fans and the engine cleared pulling it strait up and out with the flywheel and crank pully still on it, dropped the new one in same way. (TIP) with the heads removed you can get to alot of the transmission bolts from the TOP of the engine, then get the rest from the bottom with the exhaust out of the way.
you need a good set of ratchet wrenches to to get at the tranny bolts from the top, also take hood off you will get the enigne out no problem with the a hoist, just lift it a little then slide it forward, lift a little slide it forward, pitting a jack under the transmission and jacking it up will allow the transmission to come up with the engine so you can slide it out once the oil pan clears the K member, or you can just undo the oil pan and let it sit and it will drop off the engine as your lifting.
Now onto putting in our Ls7 441!
