General LSX Automobile Discussion Non-technical LSX related topics.
00 Ls1 engine noise
Old 10-14-2013, 04:41 PM
kevleetee's Avatar
Default 00 Ls1 engine noise
I have an engine noise that I think is in the valve train. When I start the car up I hear the usual piston slap knock but just after 30 seconds to a minute of running, I hear a noise that sounds like a quiet cummins diesel that starts and gets louder and then eventually goes away after the engine gets up to temp. Has anybody else experienced this?
Old 10-14-2013, 05:03 PM
SFox's Avatar
A Quiet Cummins Diesel? What is this dark magic!?
On a more serious note, check that the rockers are still tightened down well. If you have a stethoscope running around, listen to your block while it's running, you never know if it's a lower-engine (Or tranny!) sound throwing you off. Perhaps take a look to make sure the front idler isn't being funky?
Old 10-15-2013, 08:01 AM
NC01TA's Avatar
Welcome to the world of LS1 engines. Normal. Mine has done that since day 1. Yes, I'm the original owner.
Old 10-15-2013, 03:47 PM
kevleetee's Avatar
Thanks guys for the info! Does seem strange but what do I know? I'm going to check rockers and related components before I run it again.
Quick Reply: 00 Ls1 engine noise
