highway pull
highway pull
hey guys, when I do a pull from 60-65.It seems like it hangs then clears up.i just when u mash the peddle it hangs if full throttle near 60-65.Is it just torque management.it sometimes doesn't feel like its just stays at that rpm which iss weird.do these cars run fast when u don't smash the peddle all the way down because it feels like when u do 90-95 it pulls faster
LS1Tech Administrator
Received 1,490 Likes
That does not sound like TM on a stock car. If you floor it at 60-65 and nothing happens/it stays at the same rpm, then something isn't right. Could be trans or fuel related.
I've had several of these cars in stock configuration, and each one has reacted the same to WOT at those speeds (A4); a downshift to 2nd gear and strong acceleration. That's with TM still 100% active.
You could also check fuel pressure both hot and cold, if you have access to a FP gauge.
make sure u get the actual maf cleaner. maybe 'electronics' cleaner the guy at autozone tried to convince me was the same would work, but im not taking any chances, went to different places till i found maf cleaner.
I've never used actual MAF cleaner. Just rubbing alcohol and Q-tips - which has served me perfectly for this process for about 15 years now.
The OP has not been clear about his transmission type, but the fact that he's even mentioning TM leads me to believe it's an auto (since TM is really a non-issue for M6 cars). If it IS an auto, then there should be no dead spot at WOT @60-65mph, you should get a downshift to 2nd and the car should accelerate hard.
Just yesterday.
