General LSX Automobile Discussion Non-technical LSX related topics.
5.3 or 6.0?
Old 01-18-2014, 11:53 PM
sevenzeronova's Avatar
Default 5.3 or 6.0?
I am looking at converting to a new engine. Which is the better choice ? Rods difference? Wrist pins, piston?
Are there better heads to run from one or the other?
Planning on a S476 87mm 110 AR billet wheel. And holley hi ram
Old 01-22-2014, 08:31 PM
z28SSilvest's Avatar
Go 6.2
Old 01-23-2014, 06:59 PM
nascarnate326's Avatar
Pretty similar. Your going to make more power with the 6.0 but the 5.3 will easier and cheaper to find.
Personally I would go with a 5.3 but most go with the 6.0.
As long as you get an iron block you should be ok for some boost.
Old 01-26-2014, 05:51 AM
dhctss's Avatar
I would do a 5.3 and throw a huran speed kit or on3 turbo kit . Thats my plan when my engine ***** the bed. For like 4 k you could have 500 to 600 rwhp realiably and much more if desired.
Old 01-26-2014, 09:13 AM
KCS
Moderator
KCS's Avatar
5.3L engines are probably easier and less expensive. I've picked up complete 5.3L engines for $400, but the last 6.0L shortblock I bought was $350.
Look for a later model 5.3L with the stronger floating style rods.
Old 01-26-2014, 09:31 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Don't count out the 4.8L for boosted applications. If you are set on a 5.3, make sure you are actually getting a 5.3 and not a 4.8L. They share the same block, and are marked with both displacements. Pull a head, and look at the pistons. Flat-top are 4.8 and domed are 5.3.
Old 01-26-2014, 09:42 AM
Zac_Speed's Avatar
Hot Rod Magazine made over 1000hp with a 4.8 and some factory parts..
Old 01-26-2014, 10:09 AM
MonmouthCtyLS7's Avatar
Big difference would be cost...you can pick up a 4.8/5.3 for dirt cheap locally or Ebay..Costed me under 2 k in total for the motor, fresh machine work, and forged rods and pistons for my LY5.
Old 01-26-2014, 10:12 AM
KCS
Moderator
KCS's Avatar
I don't think any stock engine has domed pistons. I think you meant dished?
Anyways, another good way is to look at the area with the 4.8L/5.3L embossment and the displacement should be marked with paint. For example, a 4.8L would have a shot of paint on the 4.8L embossment.
Old 01-27-2014, 07:46 PM
408-99-f's Avatar
+1 for the 6.2L love mine. But mine is also a n/a motor. If you are going boost, and are on a budget. I would research getting a 5.3 and run 6.0 heads. I think I saw this set up in a 1500.
Quick Reply: 5.3 or 6.0?
