General LSX Automobile Discussion Non-technical LSX related topics.
Will this cam work in my 6.0?
Old 01-22-2014, 05:30 PM
Alwhite00's Avatar
Default Will this cam work in my 6.0?
http://www.summitracing.com/parts/na...FUJo7AodAwgAFw
Will the stock pushrods, springs, timing gear, etc. work with this cam? The engine is a 99 or 2000 with iron heads. Swapping on Aluminum LS1 heads.
I just would like to know what I need so when I swap the heads & cam I can have everything ready.
Thanks.
LK
Old 01-28-2014, 10:38 AM
j_tizzle_84's Avatar
what are your plans with the engine? what kind of vehicle is it going in etc. it says that is a stock ls9 cam, it was designed for boost and rectangle port heads, pretty sure no matter what cam you put in you have to change the springs.
Old 01-28-2014, 11:02 AM
redtan's Avatar
It would be pushing it with your OEM components while not really providing that much oomph since it's designed for a bigger, supercharged and square ported setup...not for an N/A 6.0 with cathedral heads.
Old 01-28-2014, 11:30 AM
Alwhite00's Avatar
Going in a 67 Chevelle - 4L60E Trans. - Any recommendations for a torq style cam?
Old 01-30-2014, 02:22 PM
mjs1012's Avatar
What size converter do you plan on using?
Old 01-30-2014, 03:06 PM
Alwhite00's Avatar
Maybe a slightly higher than stock converter, nothing radical. I like torque not 8,000 rpm HP
LK
Old 01-30-2014, 03:47 PM
mjs1012's Avatar
Somthing in the low-mid 220s should be ok. It all depends on the converter though. IMO you'd want something at least in the 3000 range. Also, I would change the springs, pushrods, timing chain, and oil pump while youre in there.
Quick Reply: Will this cam work in my 6.0?
