99 6.0 with LS2 or LS6 cam, need help
I would replace the lifters while you are there everything will match up with ls6 and I think the ls2 don't have the reluctor ring for the rear cam sensor. so you would need the front cam sensor parts.
the ls6 does the ls2 uses i cam sensor in the front timing cover that reads off the timing gear.
https://ls1tech.com/forums/generatio...-ls2-swap.html
