10k build
10k build
so far what im looking at is:
3rd gen camaro (or something with IRS)
lq4/9 or lm7
some good heads
PD cam
t56
and a roots type blower or centri type (majority of cost)
I would like it to be somewhat streetable, put down around 700-900whp, and run low tens. thoughts? can this be done? if any changes needs to be made I am willing to consider them...Thank you!~
lq4/9 or lm7
some good heads
PD cam
t56
Gonna be tough with a roots, possible with a big centri.
However on a stock engine probably won't last long at the psi you're going to be running to achieve those power goals.
Safely you can do about 600rwhp, maybe a little more. Once you're pushing close to 1k on the stock engine is no bueno.
Aluminum blocks are typically only safe around 600rwhp. But if you go LQx or iron 5.3 then I'd think you should be able to push 800-850 safely without much worry. If not then I dont get why everyone says iron blocks can handle so much more than aluminum blocks.
You'll spend you hole budget on engine swap parts and heads and cam. To build what your talking about you better double your budget. Not trying to be a dick just telling it how it is.
This, built trans/clutch/FUEL SYSTEM, rearend...etc etc......more realistic goal would be 600-650 rwhp but it's still gonna cost more than 10k to do all the supporting drivetrain mods unless you already have them.
Will you be doing all of the work & tuning yourself? If not, that's going to eat into that budget quickly.
You should be able to get the 600 - 650 rwhp mark on the dyno with $10K, however you'll need to upgrade the rear, clutch, tires etc. to get it all to the pavement at the track.
roller 2k
engine and all things considered 1k
hpt 500
supercharger with all parts 5k
cam 400
ford 9" 900
fuel setup 600
clutch 600
total 11k
I can work with a 10k to 15k budget
I will be doing all the work myself including the tuning. just a rough list i put together myself and you guys can add...
roller 2k
hpt 500
cam 400
ford 9" 900
fuel setup 600
clutch 600
total 11k
roller 2k
hpt 500
cam 400
ford 9" 900
fuel setup 600
clutch 600
total 11k
Finally, what mix of driving are you building it for? Do you want a street car that runs well on the track or are you building a track car that will occasionally get driven on the street? That will dictate where you go with suspension, tires, cage, etc.
If you're building a street car that occasionally runs at the track and are running into budget concerns, you could scrap the supercharger/turbo and go with a nitrous build. Certainly a trade-off of having constant power vs. only what's in the bottle, however it's a decent compromise if you only need the extra power at the track.
Your forgetting most of the engine swap parts and all of the engine parts that will have to be upgraded, headers, exhaust, motor mounts, trans x-member, electric fans, hoses, belts, fluids, wiring harness mods, valve springs, push rods, gaskets.... Also your list didn't even include the cost of a trans, bell housing, slave cylinder or master cylinder, and $600 clutch that can hold 600+hp good luck.
