new to the 5.3 world. need some tips
im building foxbody with a 5.3 lm7. my plan is to see what I can get out of it. I have a s474 borg warner turbo I had built 1.10 ar forward facing headers. I started building turbo kit it should be welded up this week. I have 2 intakes. the 5.3 truck int or a ls1 intake. I plan on trying to put 18 to 20 psi to it what intake should I use.
It falls off around there in N/A application... I'm sure with forced induction that wouldn't be the case.
To the OP what accessories are you going to run? I would consider more do form and function, Unless you don't mind spending the money to make one work over the other. Obviously the LS1 intake will clear under the hood, does the truck intake? Fuel system stuff as well as far as what you have and what you don't have.
Both intakes have no problem holding the boost.
