400+ ci storker or H.C.I.E. LS1?
Have the idea of starting a slow build on a 400+ iron block for the 01 SS. While looking at prices for cranks, rods, pistons, fasteners, etc... I got to thinking I could probably build the stock LS1 to respectable power for a whole lot less $$$. There's several published $8K+ builds of 408's that make about 550-ish (motor) and I know for a fact there are several 435-450 rwhp LS1's out there. Those numbers aren't all THAT far off from each other when you factor in drivetrain loss. Especially for just a weekend warrior that rarely gets driven.
I'm thinking a set of AI 243's a well matched cam and a 102 intake would get about 440 (ish) to the tires on the LS1. I could do this for about $4k with what I already have.
Any of you that have "been there done that" with either set up care to chime in as far as "If I could do it again, I'd..."
Go for the 400ci stroker! I have a heads/cam/intake LS1 in my car (number in sig) and its awesome, but if you're like most of us here, it'll be great for awhile then you'll end up wanting more, its an addiction! Might as well do it once and do it right. Just my 2 cents. It might not seem like a lot more power for the 400ci, but you have to remember youre going to have a much broader and lower torque band than with the 346 due to the extra cubes, which always makes for more fun on the street. Best of luck OP!
Best way to make power would be to go with a procharger or turbo setup. But in the end the amount of mods cost more than the car is worth. I am at the point where I dont want to put anything else in this car. Now I am just saving for a Vette.
If you were going to put together a short block 400+ inch motor what would you do? I'm trying to confirm what prices I have estimated.
408? 416? 418?
Iron? Aluminum?
I've read the COMPstar cranks and rods are good.
Summit has an iron block "ready to go" for about $800
Would you source a junkyard Lq?
What pistons?
I've never built a motor from scratch and will have a lot of questions for everyone if I go this route. Thanks for putting up with my brainstorming.
408? 416? 418?
Iron? Aluminum?
What pistons?
I had the thought of a "sleeper" lsx build today. A.I. 241's with a matched cam and a ported ls6 intake with a stroker ls1. I'd claim "cam" only all damn day long with no signs of foul play. Not that I ever race any damn way but that's not the point!
I still can't get rid of the thought of a 418 or 427. It's just too damn cool to say you have a 427!
They'll work well.
Don't always look at the peak numbers. Most people will always say, "I can make that horsepower in my LS1. Strokers are a waste."
Yes, it is true that you can achieve the same peak horsepower number in your LS1 that someone else has achieved in their 383/402/408. Hell, I only gained 30 peak horsepower over my LS2 set-up using the same intake and heads.
HOWEVER, I also gained 70 lb-ft of peak torque, and consistently gained everywhere else throughout the RPM band.
