Car options
Car options
I have a 1995 Camaro z28, I'm not satisfied with the powerplant inside of it, should I just buy an 02 body style z28 or ss or should I buy an 02 WS6, its hard choice!
LS1Tech Administrator
Received 1,489 Likes
If you like the car but aren't satisfied with the power, there are plenty of options for adding more power to your current LT1....or even an LSx swap could be done into your current car.
If you just want another car, then that's another story.
The only differences between the Chevrolet and Pontiac versions of the F-body are standard options and cosmetics, otherwise they are the same car. Only you can decide which one you like the appearance of better, so the opinions of others really don't matter in this regard.
As far as simplicity is concerned, buying an LS1 F-Body is going to be your best bet. But if you want something unique, LS-swap your Z28. I want to LS-swap a 3rd generation one day myself.
Like RPM_WS6 said, between Camaro's and Trans-Am's, the only difference is going to be interior and body. Powerplants are the same. I'm pretty sure that Camaro's can be had for cheaper; all variable being the same.
I was thinking an LQ4 408 stroker with a lopey cam and twin turbos, but this is off subject do people on here do meet ups and go cruise all over the place or is that highly unlikely? lol
That to depends on where you are and people being I here that live near you. I like hanging out with friends and going cruising.
