high octane questions
I did a search and wasn't able to come up with any answers. I curious to know if I put 110 octane in my car mix with 93, will that improve performance or harm it? Current mods are bolt - ons with a tune.
A higher octane-rating signifies the fuel is harder to detonate under compression. So, unless you're tuned for higher octane fuel or are running high-compression (and thus tuned for it), there's no improvement with an octane booster.
So it won't harm performance, just not do anything for it. At least it should clean my fuel system...right? I'm getting it free so it's not a big deal. I just want make sure I don't **** my car up.
My grandfather, for years, purchased 93 Octane fuel for his Prism (4 cylinder econobox) and I always wondered why he did that, but he was the type of guy that you didn't question his motives. Well... he wasn't necessarily a car guy and he wasted a lot of cash on that fuel.
as long as it's unleaded 110 that is safe for catalytic converters then you won't hurt anything. don't expect higher octane to clean better or worse. what does any cleaning would be the detergent additives in gasoline, which has nothing to do with octane. and then how well those additives clean the back side of the intake valve or not leave deposits is unknown as far as i'm concerned, nothing out there conclusive.
LS1Tech Administrator
Received 1,489 Likes
110 in an application that only requires 93 will in fact harm performance or at least MPG. The higher octane is more resistant to combustion (to prevent detonation), so if you don't have a need for the slower, harder burn (such as higher compression and/or more aggressive tuning as mentioned above, and/or hotter combustion temps due to FI, etc.) then you can only stand to lose overall performance with a higher, unnecessary octane.
A given engine will attain best power and MPG when the lowest possible octane is used that still 100% resists detonation (knock, pre-ignition) in said application in a same-conditions comparison.
A point or two of higher than needed octane probably won't make much difference, but if all you need for your current setup is 91-93 octane to resist all detonation, and you dump in a tank of 110, I would expect to see some amount of reduction in overall performance, including MPG.
More octane per mass of fuel will put more potential energy into your cylinder. Carbon and Hydrogen. Question is can you get it hot enough to burn it all and collect it? Can you collect more energy than when burning 93? maybe
