O6 silverado turbo build and nitrous
You can easily do better than the Z06 cam which is better suited for a SC with it's wide split; not Turbo. IMO, I'd go with a single pattern cam, but a reverse split with a small split like 2-4 degrees should also work good, an make sure the cam lobes are fairly mild, NOT aggressive. Furthermore if you want it to run fairly smooth go no larger than a 220(@.05") duration with a 114-115lsa.
http://www.speedinc.com/shop-by-vehi...m-216-216.html
http://www.ws6project.com/user_stor/...oducts_id=4923
http://www.mcssl.com/store/cammotion/turbo-stage-
FYI, the Speed Inc. cam has -12* Over Lap, Crane cam has -14* OL., and the Cam Motion cam has -10* OL..
Thanks for the advice. I'll look into that. Any other advice on this build? This is my first turbo build so I'm taking all the advice I can get. Lol
http://texas-speed.com/p-2975-texas-...-camshaft.aspx
Heard anything about this one?
