Oil pressure gauge-mechanical or electric?
Most accurate would be a mechanical gauge since you're reading pressure directly off the block. You're not depending on an electrical sender to give a signal to the gauge. Easiest install is an electrical gauge since you're just dealing with some light gauge wiring and a small sending unit.
you can tap in right above the oil filter as there's a cover you can take off. don't forget with a mechanical gauge you're running a line that will be under pressure into the interior of your car. if that line develops a hole or leaks you will be pumping oil into the inside of your car!
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
Also found this item says it will work with GM 5.7 liter
